[GRASS-dev] On `svn propset`
Nikos Alexandris
nik at nikosalexandris.net
Sun Jan 13 10:00:48 PST 2019
* Markus Neteler <neteler at osgeo.org> [2019-01-13 14:53:13 +0100]:
>Do you run that manually or use the helper script
>grass-addons/tools/module_svn_propset.sh *
Manually. TL;DR
The properties seem to be already set and there is no need to re-set them.
Perhaps, once set for a file, in an SVN repository, there is no need for
a re-set? Even if actually replacing a file (instead of updating it)
with a file from a(nother) non-SVN repository, and committing the update.
What I did/tried:
# 1 : Print working directory
pwd
/osgeo/grass-addons/grass7/raster/r.estimap.recreation
# 2 : Update (here == replace) the Python script
cp /some/local/repository/r.estimap.recreation.py /osgeo/grass-addons/grass7/raster/r.estimap.recreation/r.estimap.recreation.py
cp: overwrite '/osgeo/grass-addons/grass7/raster/r.estimap.recreation/r.estimap.recreation.py'? y
# 3 : committing the change to the SVN repository
svn ci -m "r.estimap.recreation.py: remove left-over 'd' flag" r.estimap.recreation.py
# which is: https://trac.osgeo.org/grass/changeset/73931
# 4 : I realise(d) I forgot to set the file properties
file r.estimap.recreation.py
r.estimap.recreation.py: Python script, UTF-8 Unicode text executable, with very long lines
# 5 : Setting them manually and testing again
svn propset svn:eol-style "native" r.estimap.recreation.py
property 'svn:eol-style' set on 'r.estimap.recreation.py'
svn propset svn:mime-type text/x-python r.estimap.recreation.py
property 'svn:mime-type' set on 'r.estimap.recreation.py'
No effect!
# 5 : Trying to use the script:
sh ../../../tools/module_svn_propset.sh r.estimap.recreation.py
# No change again!
# 6 : From withing a GRASS GIS session maybe? Repeating the last two
# commands, does nothing.
# 7 : Last check
svn propget svn:mime-type r.estimap.recreation.py
text/x-python
svn propget svn:eol-style r.estimap.recreation.py
native
# How can this be? Properties are already set.
Nikos
