[GRASS-dev] On `svn propset`
Markus Neteler
neteler at osgeo.org
Sun Jan 13 10:38:30 PST 2019
On Sun, Jan 13, 2019 at 7:05 PM Nikos Alexandris
<nik at nikosalexandris.net> wrote:
> * Markus Neteler <neteler at osgeo.org> [2019-01-13 14:53:13 +0100]:
> >Do you run that manually or use the helper script
> >grass-addons/tools/module_svn_propset.sh *
> Manually. TL;DR
> The properties seem to be already set and there is no need to re-set them.
There is no harm to run the script. It saves you likely quite some time :-)
Trying that locally didn't change anything.
Question: what's wrong and you don't like? Maybe I don't get it...
Markus
