[GRASS-dev] On `svn propset`
Nikos Alexandris nik at nikosalexandris.net
Sun Jan 13 12:15:54 PST 2019
* Markus Neteler <neteler at osgeo.org> [2019-01-13 19:38:30 +0100]:
>On Sun, Jan 13, 2019 at 7:05 PM Nikos Alexandris
><nik at nikosalexandris.net> wrote:
>> * Markus Neteler <neteler at osgeo.org> [2019-01-13 14:53:13 +0100]:
>> >Do you run that manually or use the helper script
>> >grass-addons/tools/module_svn_propset.sh *
>> Manually. TL;DR
>> The properties seem to be already set and there is no need to re-set them.
>There is no harm to run the script. It saves you likely quite some time :-)
I did. But I maybe I don't understand it well yet.
>Trying that locally didn't change anything.
>Question: what's wrong and you don't like? Maybe I don't get it...
Nothing. Why?  What I don't like perhaps is that I forget such details
and indirectly create work for others.
Thanks Markus, Nikos
