[GRASS-dev] On `svn propset`
Vaclav Petras
wenzeslaus at gmail.com
Mon Jan 14 18:39:50 PST 2019
On Sun, Jan 13, 2019 at 12:59 PM Nikos Alexandris <nik at nikosalexandris.net>
wrote:
> The properties seem to be already set and there is no need to re-set them.
> Perhaps, once set for a file, in an SVN repository, there is no need for
> a re-set? Even if actually replacing a file (instead of updating it)
> with a file from a(nother) non-SVN repository, and committing the update.
Good question. Subversion (as well as Git) does look at the content of the
file not at the creation date or anything like that. Replacing a file is
the same as modifying it from point of view of the common versioning
control systems. (Renaming file is a different story.)
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190114/6bd9dc33/attachment.html>
