[GRASS-dev] Unable to install manual for add-on r.estimap.recreation under Windows
Nikos Alexandris nik at nikosalexandris.net
Mon Jan 14 06:29:34 PST 2019
* Stefan Blumentrath <Stefan.Blumentrath at nina.no> [2019-01-14 14:03:29 +0000]:
>A first swift answer: Currently, making an addon available in QGIS is
>quite similar comparing the options GRASS plugin and processing. In
>both cases you will have to redefine the GUI in either txt or xml.
Stefan, I don't think it's the same in terms of effor.  I'll post the
instructions for 'Processing' and I think you will see the amount of
work you need to put there-in to add additional logic to the existing
(Python) methods.
Nikos
>That has been a design choice in QGIS (as modules were supposed to be
>simplified in QGIS).
>That was one thing that Radek was trying to address when he started the
>GSoC project to overhaul GRASS integration in Processing for QGIS 3 (if
>I remember correctly). But this is unfinished work I am afraid...
>Cheers Stefan
[rest deleted]
