[GRASS-dev] Unable to install manual for add-on r.estimap.recreation under Windows
Nikos Alexandris nik at nikosalexandris.net
Tue Jan 15 08:25:21 PST 2019
* Nikos Alexandris <nik at nikosalexandris.net> [2019-01-14 15:29:34 +0100]:
>* Stefan Blumentrath <Stefan.Blumentrath at nina.no> [2019-01-14 14:03:29 +0000]:
>>A first swift answer: Currently, making an addon available in QGIS is
>>quite similar comparing the options GRASS plugin and processing. In
>>both cases you will have to redefine the GUI in either txt or xml.
>Stefan, I don't think it's the same in terms of effor.  I'll post the
>instructions for 'Processing' and I think you will see the amount of
>work you need to put there-in to add additional logic to the existing
>(Python) methods.
Here a first draft: https://trac.osgeo.org/grass/wiki/QGIS-Processing-GRASS-Provider
I tool the liberty to retouch the text I received from Médéric Ribreux
(in Cc).
Nikos
