[GRASS-dev] Testsuite: script for easier use of test framework
Markus Neteler neteler at osgeo.org
Thu Jan 17 08:11:03 PST 2019
On Wed, Jan 16, 2019 at 9:53 PM Vaclav Petras <wenzeslaus at gmail.com> wrote:
(just quickly while being busy right now)
> I changed the location on fatra to full NC SPM and did the rename as you suggested. I don't know how
> many tests does this affect, but in any case tomorrow we will know if I at least set the things correctly.
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2019-01-17-08-00/report_for_nc_spm_full_v2alpha_nc/testsuites.html
It seems that it failed. Importantly, the 5 or so maps need to be
_copied_ under new name, not remnamed.
Would you mind to check again?
thanks
Markus
