[GRASS-dev] Testsuite: script for easier use of test framework
Vaclav Petras
wenzeslaus at gmail.com
Mon Jan 21 12:46:05 PST 2019
On Mon, Jan 21, 2019 at 3:08 PM Markus Neteler <neteler at osgeo.org> wrote:
> On Mon, Jan 21, 2019 at 1:48 AM Vaclav Petras <wenzeslaus at gmail.com>
> wrote:
> > Any reason for the file, i.e. can this be in the documentation?
> Not only because...
> > Or do you want a simpler example in doc and a link to the source code
> with more complex or ready-to-use examples?
> ... I need to be able to automatically call the script to test an
> installation.
> We are deploying GRASS GIS in a cloud environment (Openshift based)
> and cannot manually copy-paste scripts from the documentation.
OK, this raises the question if I should put the exact script I'm using at
fatra.cnr.ncsu.edu to GRASS GIS code? I based the example in doc on that
but considered the actual script as too specific (it needs to have the
hardcoded paths anyway).
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190121/809ebefc/attachment.html>
