[GRASS-dev] Testsuite: script for easier use of test framework
Markus Neteler
neteler at osgeo.org
Mon Jan 21 12:59:07 PST 2019
On Mon, Jan 21, 2019 at 9:34 PM Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Mon, Jan 21, 2019 at 3:08 PM Markus Neteler <neteler at osgeo.org> wrote:
>> On Mon, Jan 21, 2019 at 1:48 AM Vaclav Petras <wenzeslaus at gmail.com> wrote:
>> > Any reason for the file, i.e. can this be in the documentation?
>> Not only because...
>> > Or do you want a simpler example in doc and a link to the source code with more complex or ready-to-use examples?
>> ... I need to be able to automatically call the script to test an installation.
>> We are deploying GRASS GIS in a cloud environment (Openshift based)
>> and cannot manually copy-paste scripts from the documentation.
> OK, this raises the question if I should put the exact script I'm using at fatra.cnr.ncsu.edu to GRASS GIS code?
Ah, in order to also run it directly, right?
> I based the example in doc on that but considered the actual script as too specific (it needs to have the hardcoded paths anyway).
Perhaps it might be the best to store the hardcoded paths in a
separate config file which is "source"d by the test script?
Markus
