[GRASS-dev] Testsuite: script for easier use of test framework
Markus Neteler neteler at osgeo.org
Mon Jan 21 14:34:03 PST 2019
On Mon, Jan 21, 2019 at 11:14 PM Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Mon, Jan 21, 2019 at 3:59 PM Markus Neteler <neteler at osgeo.org> wrote:
>> On Mon, Jan 21, 2019 at 9:34 PM Vaclav Petras <wenzeslaus at gmail.com> wrote:
>> > OK, this raises the question if I should put the exact script I'm using at fatra.cnr.ncsu.edu to GRASS GIS code?
>> Ah, in order to also run it directly, right?
>> > I based the example in doc on that but considered the actual script as too specific (it needs to have the hardcoded paths anyway).
>> Perhaps it might be the best to store the hardcoded paths in a
>> separate config file which is "source"d by the test script?
> That's a good idea. That way I we could actually run it directly without storing the specific settings in the source code.
Changed in r73993.
Please try.
Markus
