[GRASS-dev] [GRASS GIS] #3740: The GRASS session is "leaking" to the environment
trac at osgeo.org
Mon Jan 28 13:57:39 PST 2019
Reporter: pmav99 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Startup | Version: svn-trunk
Resolution: | Keywords:
CPU: Unspecified | Platform: Linux
Comment (by pmav99):
Replying to [comment:3 mmetz]:
> Replying to [comment:2 pmav99]:
> > OK, after writing `exit` on the console, the GRASS session finally
exits.
> The script `run_gui.sh` calls grass77 which establishes a GRASS session
on the command line. The GUI is only started with grass77 --gui, or if the
stored settings indicate that the last time GRASS was started with a GUI.
I am sorry but I think this is not accurate. Please correct me if I am
wrong, but ''the very first time'' you run the `grass77` executable, you
don't get the CLI, you get the GUI. At least that's what I observe. If you
want to change the behavior you need to call `grass77` with the
`--text/--gtext` argument. So the `--gui` argument is the default one, not
the other way around.
That being said, and I guess that this is the main issue here, the dialog
you get when you press `ctrl+Q` is IMHO confusing. As far as I can tell,
both the `Close GUI` and the `Quit GRASS GIS` button do the exact same
thing, i.e. they return me to the GRASS shell, from which I need to `exit`
in order to return to my regular shell. I could be wrong though. Perhaps
there is some other difference which I don't know about.
Nevertheless, I do find confusing that I have to Quit GRASS twice. Once in
the GUI and once in the console. I would expect that the `Quit GRASS`
button returns me to my own shell. If not, what is the point of having
both that one and the `Close GUI` button?
[[Image(https://i.imgur.com/NlLfc44.png)]]
Ticket URL: <https://trac.osgeo.org/grass/ticket/3740#comment:4>
