[GRASS-dev] [GRASS GIS] #3740: The GRASS session is "leaking" to the environment
trac at osgeo.org
Mon Jan 28 14:28:14 PST 2019
Reporter: pmav99 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Startup | Version: svn-trunk
Resolution: | Keywords:
CPU: Unspecified | Platform: Linux
Comment (by pmav99):
The relevant code seems to be this (_1):
2599 def _quitGRASS(self):
2600 """Quit GRASS terminal"""
2601 try:
2602 shellPid = int(grass.gisenv()['PID'])
2603 except:
2604 grass.warning(_("Unable to exit GRASS shell: unknown
PID"))
2605 return
2606
2607 Debug.msg(1, "Exiting shell with
pid={0}".format(shellPid))
2608 import signal
2609 os.kill(shellPid, signal.SIGTERM)
The logic of the code that calls `_quitGRASS` seems AFAI can tell correct.
I don't see the warning on the console, so assuming that warnings do get
logged by default, the problem could be in the `os.kill` call. To be
honest, the main reason I was using `exec` in the first place was to have
proper signal propagation (_2). Could someone tell me how can I increase
the log level?
_1:
https://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/lmgr/frame.py#L2599
_2: https://unix.stackexchange.com/a/196053/37579
Ticket URL: <https://trac.osgeo.org/grass/ticket/3740#comment:5>
