[GRASS-dev] [GRASS GIS] #3502: v.proj location not set in dialog
GRASS GIS trac at osgeo.org
Tue Jan 29 07:50:57 PST 2019
  Reporter:  balagates  |      Owner:  grass-dev@…
      Type:  defect     |     Status:  new
  Priority:  normal     |  Milestone:  7.2.4
 Component:  wxGUI      |    Version:  7.4.0
Resolution:             |   Keywords:  v.proj location
       CPU:  OSX/Intel  |   Platform:  MacOSX
Comment (by balagates):
 I now have access to Grass 7.4.0 with wxPython 3.0.2.0 on Ubuntu 18.04. In
 this version v.proj location works as expected. Therefore, this problem is
 likely due to some difference in OS (macOS vs Linux), likely in the
 wxPython implementation.  I verified the source on Ubuntu is
 win.Bind(wx.EVT_TEXT,...).  The older code still makes more sense to me.
 Not sure if there is some benefit to the newer change.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3502#comment:3>
