[GRASS-dev] [GRASS GIS] #3502: v.proj location not set in dialog
trac at osgeo.org
Tue Jan 29 12:12:29 PST 2019
Reporter: balagates | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.4
Component: wxGUI | Version: 7.4.0
Resolution: | Keywords: v.proj location
CPU: OSX/Intel | Platform: MacOSX
Comment (by hellik):
Replying to [comment:3 balagates]:
> I now have access to Grass 7.4.0 with wxPython 3.0.2.0 on Ubuntu 18.04.
In this version v.proj location works as expected. Therefore, this problem
is likely due to some difference in OS (macOS vs Linux), likely in the
wxPython implementation. I verified the source on Ubuntu is
win.Bind(wx.EVT_TEXT,...). The older code still makes more sense to me.
Not sure if there is some benefit to the newer change.
there is now GRASS 7.6 released; any chance to test it there?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3502#comment:4>
