[GRASS-dev] how to backport in git(hub)?
Helmut Kudrnovsky
hellik at web.de
Tue Jul 16 01:13:46 PDT 2019
hi,
https://github.com/OSGeo/grass/pull/53
is labelled as backport needed.
in https://trac.osgeo.org/grass/wiki/HowToGit#Backportingofasinglecommit
# temporarily switch to master
git checkout master
# update master to fetch the commit to be backported
git fetch --all --prune
# Note: only needed if you have your fork as "origin" (see above)
# update local repo
## NO git pull origin releasebranch_7_6 --rebase
# merge updates into local master
git merge upstream/releasebranch_7_6
# at this point we have reached:
# (HEAD -> master, upstream/releasebranch_7_6, releasebranch_7_6)
# ??? update own remote
git push origin releasebranch_7_6
# ??? With git log, identify the sha1sum of the commit you want to backport
(example: backport into releasebranch_7_6)
git log
# switch to branch
git checkout releasebranch_7_6
# now backport the commit (edit conflicts if needed)
git cherry-pick the_sha1_sum
# verify
git show
# push backport to upstream
git push upstream releasebranch_7_6
are all these steps needed for backporting a single commit like pull/53?
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
