[GRASS-dev] how to backport in git(hub)?
Martin Landa
landa.martin at gmail.com
Tue Jul 16 03:04:52 PDT 2019
I am using simplified workflow:
(assumming that we are in releasebranch_7_6 branch)
git fetch --all
git rebase upstream/releasebranch_7_6
git cherry-pick hash
(or
git cherry-pick -m1 hash
when cherry picking a merge request
git push upstream releasebranch_7_6
Ma
Ășt 16. 7. 2019 v 10:13 odesĂlatel Helmut Kudrnovsky <hellik at web.de> napsal:
> hi,
> https://github.com/OSGeo/grass/pull/53
> is labelled as backport needed.
> in https://trac.osgeo.org/grass/wiki/HowToGit#Backportingofasinglecommit
> # temporarily switch to master
> git checkout master
> # update master to fetch the commit to be backported
> git fetch --all --prune
> # Note: only needed if you have your fork as "origin" (see above)
> # update local repo
> ## NO git pull origin releasebranch_7_6 --rebase
> # merge updates into local master
> git merge upstream/releasebranch_7_6
> # at this point we have reached:
> # (HEAD -> master, upstream/releasebranch_7_6, releasebranch_7_6)
> # ??? update own remote
> git push origin releasebranch_7_6
> # ??? With git log, identify the sha1sum of the commit you want to backport
> (example: backport into releasebranch_7_6)
> git log
> # switch to branch
> git checkout releasebranch_7_6
> # now backport the commit (edit conflicts if needed)
> git cherry-pick the_sha1_sum
> # verify
> git show
> # push backport to upstream
> are all these steps needed for backporting a single commit like pull/53?
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
