[GRASS-dev] extra verbosity in temporal commands
Vaclav Petras wenzeslaus at gmail.com
Mon Jul 29 17:06:44 PDT 2019
On Mon, Jul 29, 2019 at 7:45 PM Veronica Andreo <veroandreo at gmail.com>
wrote:
> Hi devs,
> I have noticed since last week or so that every time I run a temporal
> command, it clutters my terminal with "internal" stuff from the module. I
> have not changed verbosity level. Could it be that some library change
> produced that or some remaining debugging setting??
> Here's an example of what I see:
> .rast.series input=month_max_LST_per_year   output=slope_month_max_LST
> method=slope --o
>  100%
> UPDATE raster_base SET  name = 'slope_month_max_LST'  ,creator =
> 'veroandreo'  ,mapset = 'modis_lst'  ,creation_time = '2019-07-30
> 01:40:56.813449'  ,temporal_type = 'absolute'  ,id =
> 'slope_month_max_LST at modis_lst' WHERE id = 'slope_month_max_LST at modis_lst
> UPDATE raster_absolute_time SET  start_time = '2015-01-01 00:00:00'  ,id =
> 'slope_month_max_LST at modis_lst'  ,end_time = '2018-01-01 00:00:00' WHERE
> id = 'slope_month_max_LST at modis_lst';
> UPDATE raster_spatial_extent SET  north = 323380.124115  ,bottom =
> 0.000000  ,west = 122934.464115  ,top = 0.000000  ,proj = 'XY'  ,east =
> 934934.464115  ,id = 'slope_month_max_LST at modis_lst'  ,south =
> 9780.124115 WHERE id = 'slope_month_max_LST at modis_lst';
> UPDATE raster_metadata SET  max = 1.500000  ,rows = 145  ,min = -2.000000
>  ,datatype = 'DCELL'  ,number_of_cells = 8120  ,cols = 56  ,ewres =
> 5600.000000  ,nsres = 5600.000000  ,id = 'slope_month_max_LST at modis_lst'
> UPDATE raster_stds_register SET  id = 'slope_month_max_LST at modis_lst'
>  ,registered_stds = NULL WHERE id = 'slope_month_max_LST at modis_lst';
> Any hints?
Hi Vero,
This looks like some forgotten debug messages/prints, but just to be sure,
first check that you did not switch on debug mode (g.gisenv). I don't see
changes in temporal code, but perhaps I'm missing something.
Related to that (from user perspective), have you tried --qq recently? It
didn't seem to work for me.
Vaclav
> Vero
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190729/23397a74/attachment.html>
