[GRASS-dev] extra verbosity in temporal commands
Veronica Andreo
veroandreo at gmail.com
Mon Jul 29 18:31:38 PDT 2019
Hi Vashek,
No, I haven't changed anything with g.gisenv. There were not recent changes
in the temporal stuff that I am aware of. Maybe some forgotten debug
messages/prints in more low level python library change?? No idea, I just
started noticing last week in a two weeks old grass77.
I haven't tried it. Is it supposed to work with all modules? The same
command I showed before with --qq gives error "that's not a valid flag"
Vero
El mar., 30 jul. 2019 a las 2:05, Vaclav Petras (<wenzeslaus at gmail.com>)
escribió:
> On Mon, Jul 29, 2019 at 7:45 PM Veronica Andreo <veroandreo at gmail.com>
> wrote:
>> Hi devs,
>> I have noticed since last week or so that every time I run a temporal
>> command, it clutters my terminal with "internal" stuff from the module. I
>> have not changed verbosity level. Could it be that some library change
>> produced that or some remaining debugging setting??
>> Here's an example of what I see:
>> .rast.series input=month_max_LST_per_year output=slope_month_max_LST
>> method=slope --o
>> 100%
>> UPDATE raster_base SET name = 'slope_month_max_LST' ,creator =
>> 'veroandreo' ,mapset = 'modis_lst' ,creation_time = '2019-07-30
>> 01:40:56.813449' ,temporal_type = 'absolute' ,id =
>> 'slope_month_max_LST at modis_lst' WHERE id = 'slope_month_max_LST at modis_lst
>> UPDATE raster_absolute_time SET start_time = '2015-01-01 00:00:00' ,id
>> = 'slope_month_max_LST at modis_lst' ,end_time = '2018-01-01 00:00:00'
>> WHERE id = 'slope_month_max_LST at modis_lst';
>> UPDATE raster_spatial_extent SET north = 323380.124115 ,bottom =
>> 0.000000 ,west = 122934.464115 ,top = 0.000000 ,proj = 'XY' ,east =
>> 934934.464115 ,id = 'slope_month_max_LST at modis_lst' ,south =
>> 9780.124115 WHERE id = 'slope_month_max_LST at modis_lst';
>> UPDATE raster_metadata SET max = 1.500000 ,rows = 145 ,min = -2.000000
>> ,datatype = 'DCELL' ,number_of_cells = 8120 ,cols = 56 ,ewres =
>> 5600.000000 ,nsres = 5600.000000 ,id = 'slope_month_max_LST at modis_lst'
>> UPDATE raster_stds_register SET id = 'slope_month_max_LST at modis_lst'
>> ,registered_stds = NULL WHERE id = 'slope_month_max_LST at modis_lst';
>> Any hints?
> Hi Vero,
> This looks like some forgotten debug messages/prints, but just to be sure,
> first check that you did not switch on debug mode (g.gisenv). I don't see
> changes in temporal code, but perhaps I'm missing something.
> Related to that (from user perspective), have you tried --qq recently? It
> didn't seem to work for me.
> Vaclav
>> Vero
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190730/3f1c6dfd/attachment-0001.html>
