[GRASS-dev] [GRASS GIS] #3858: r.mapcalc - Add warning when the same map is used both as an input and an output
trac at osgeo.org
Sat Jun 1 02:59:52 PDT 2019
output
Reporter: Hygsson | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.6.2
Component: Raster | Version: unspecified
Keywords: r.mapcalc | CPU: x86-64
Platform: MSWindows 7 |
A map cannot be used both as an input and as an output as in this invalid
expression `oldmap = oldmap + 1`, instead a subsequent rename using
`g.rename` is needed when the same name is desired:
r.mapcalc "newmap = oldmap + 1"
g.rename raster=newmap,oldmap
While `(oldmap = oldmap + 1)` may work on Linux, it will result in error
on Windows.
As Wenzeslaus suggested in ticket:3857#comment:1, the solution might be to
check inputs and outputs beforehand and add a warning for Linux and an
error message for MS Windows.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3858>
