[GRASS-dev] instructions to update my local copy of trunk
Veronica Andreo
veroandreo at gmail.com
Sun Jun 2 11:58:44 PDT 2019
Hi devs
Following instructions here:
https://trac.osgeo.org/grass/wiki/HowToGit#Keepyourlocalsourcecodeuptodate,
I get:
[veroandreo at localhost grass7_trunk]$ git remote -v
origin git at github.com:veroandreo/grass.git (fetch)
origin git at github.com:veroandreo/grass.git (push)
upstream git at github.com:OSGeo/grass.git (fetch)
upstream git at github.com:OSGeo/grass.git (push)
[veroandreo at localhost grass7_trunk]$ git fetch upstream
remote: Enumerating objects: 242, done.
remote: Counting objects: 100% (242/242), done.
remote: Compressing objects: 100% (25/25), done.
remote: Total 296 (delta 223), reused 233 (delta 217), pack-reused 54
Receiving objects: 100% (296/296), 56.83 KiB | 1.18 MiB/s, done.
Resolving deltas: 100% (226/226), completed with 105 local objects.
>From github.com:OSGeo/grass
* [new branch] changelog_fix_msg -> upstream/changelog_fix_msg
3797ccaaf..b300e66fc master -> upstream/master
1ca5e4e34..e1e13d782 releasebranch_7_4 -> upstream/releasebranch_7_4
15f53e803..dcfce280b releasebranch_7_6 -> upstream/releasebranch_7_6
[veroandreo at localhost grass7_trunk]$ git branch -a
* master
remotes/origin/master
remotes/origin/releasebranch_7_0
remotes/origin/releasebranch_7_2
remotes/origin/releasebranch_7_4
remotes/origin/releasebranch_7_6
remotes/upstream/changelog_fix_msg
remotes/upstream/master
remotes/upstream/releasebranch_7_0
remotes/upstream/releasebranch_7_2
remotes/upstream/releasebranch_7_4
remotes/upstream/releasebranch_7_6
[veroandreo at localhost grass7_trunk]$ git rebase upstream/master
First, rewinding head to replay your work on top of it...
Fast-forwarded master to upstream/master.
[veroandreo at localhost grass7_trunk]$ git status
On branch master
Your branch is ahead of 'origin/master' by 51 commits.
(use "git push" to publish your local commits)
Why does my origin/master is now ahead by 51 commits, if I have not a
single local change? I just want to get the new stuff from upstream and
update my fork and local copy of the source code (what I used to do with
`svn update`).
Can someone please provide full instructions [ideally in
https://trac.osgeo.org/grass/wiki/HowToGit#Keepyourlocalsourcecodeuptodate]?
Thanks much in advance
Vero
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190602/317120ec/attachment.html>
