[GRASS-dev] instructions to update my local copy of trunk
Markus Neteler neteler at osgeo.org
Sun Jun 2 12:40:46 PDT 2019
On Sun, Jun 2, 2019 at 8:59 PM Veronica Andreo <veroandreo at gmail.com> wrote:
> Hi devs
> Following instructions here: https://trac.osgeo.org/grass/wiki/HowToGit#Keepyourlocalsourcecodeuptodate, I get:
> [veroandreo at localhost grass7_trunk]$ git status
> On branch master
> Your branch is ahead of 'origin/master' by 51 commits.
>   (use "git push" to publish your local commits)
> Why does my origin/master is now ahead by 51 commits, if I have not a single local change? I just want to get the new stuff from upstream and update my fork and local copy of the source code (what I used to do with `svn update`).
> Can someone please provide full instructions [ideally in https://trac.osgeo.org/grass/wiki/HowToGit#Keepyourlocalsourcecodeuptodate]?
I have pretty much the same issue on the GRASS Server, trying to
update the cronjobs:
# here on relbranch76:
neteler at osgeo6:~/cronjobs$ sh cron_grass76_src_relbr76_snapshot.sh
Sun Jun  2 12:33:42 PDT 2019
Already on 'releasebranch_7_6'
Your branch is up-to-date with 'origin/releasebranch_7_6'.
git update...
>From https://github.com/OSGeo/grass
 * branch            releasebranch_7_6 -> FETCH_HEAD
Updating 2340b9d..dcfce28
Fast-forward
 README => README.md                     |  78
 doc/howto_release.txt                   |   3 +--
 include/Make/Docs.make                  |  10 +++-------
 lib/python/pygrass/modules/grid/grid.py |   7 +++++++
 raster/r.stream.extract/main.c          |   6 +++---
 tools/gitlog2changelog.py               | 133
 vector/v.db.connect/main.c              |  24 +++++++++++++-----------
 7 files changed, 208 insertions(+), 53 deletions(-)
 rename README => README.md (51%)
 create mode 100755 tools/gitlog2changelog.py
On branch releasebranch_7_6
Your branch is ahead of 'origin/releasebranch_7_6' by 6 commits.
nothing to commit, working directory clean
Something is clearly missing in the "HowToGit"...
Help welcome.
thanks
Markus
