[GRASS-dev] [GRASS GIS] #3860: GRASS GIS producing different slope than GDAL
trac at osgeo.org
Sun Jun 9 13:47:33 PDT 2019
Reporter: mazingaro | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.6.2
Component: Raster | Version: unspecified
Keywords: slope | CPU: x86-64
Platform: Linux |
2
When producing a slope in GRASS GIS 7.4 and 7.6 the results are different
than with QGIS (GDAL) and ArcMap for the same input data and same
parameter (Z ratio is 1.0 and degrees). QGIS and ArcMap generate almost
the same output. In GRASS, I tried both for DCELL and FCELL and the
results are same. The original layer has a resolution on 1 m and the GRASS
region resolution is set to 0.5 m.
Code GRASS: r.slope.aspect elevation=DMR at PERMANENT slope=slope
Code GDAL: gdaldem slope .../DMR.tif .../slope.tif -of GTiff -b 1 -s 1.0
Do I do something wrong or this can be a bug?
[[Image(https://i.stack.imgur.com/Y0bVF.jpg)]]
Left - GRASS calculated slope and right - GDAL calculated one
Ticket URL: <https://trac.osgeo.org/grass/ticket/3860>
