[GRASS-dev] datetime function in v.in.ogr
Markus Metz
markus.metz.giswork at gmail.com
Thu Jun 27 14:05:05 PDT 2019
On Thu, Jun 27, 2019 at 9:27 PM Paulo van Breugel <p.vanbreugel at gmail.com>
wrote:
> Hi devs,
> I am trying to import a shapefile using v.in.ogr, filtering on date
> using datetime, e.g.,
> v.in.ogr input=myshapefile.shp layer=myshapefile output=outputlayer
> where="datm_start >= datetime('2019-01-01')"
> I am getting the message:
> ERROR 1: Undefined function 'datetime' used.
> ERROR: Error setting attribute filter 'datm_start >=
datetime('2019-01-01')'
> Does this mean it is not possible to use functions in v.in.ogr? Or am I
> doing somthing wrong?
The OGR shapefile driver does not support this function. You need to import
the shapefile into GRASS, using anything but the dbf driver as database
driver (default is sqlite), then try to filter with v.extract
HTH,
Markus M
> Running grass gis 7.6, Linux.
> Cheers,
> Paulo
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190627/67d4f427/attachment.html>
