[GRASS-dev] [GRASS GIS] #3772: Make the grass library importable outside of a GRASS session
trac at osgeo.org
Tue Mar 5 09:20:02 PST 2019
Reporter: pmav99 | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone:
Component: Python | Version: svn-trunk
Resolution: | Keywords:
CPU: Unspecified | Platform: Unspecified
Comment (by pmav99):
The proposed change is not directly comparable to {{{grass-session}}}.
They have different scopes.
To make this more clear:
{{{grass-session}}} is a 3rd party library that can be used to
programmatically create a GRASS session.
If {{{grass-session}}} was implemented in the {{{grass}}} library itself,
then, since you can't import the {{{grass}}} library unless you already
are inside a GRASS session, we would have a chicken-egg problem. I.e. in
order to create a GRASS session we would need to already be inside a GRASS
session.
That's why {{{grass-session}}} needs to be a 3rd party library.
So, if the {{{grass}}} library becomes importable, then, {{{grass-
session}}} would have a cleaner implementation and eventually, {{{grass-
session}}} could be implemented in the {{{grass}}} library itself, with
obvious benefits (e.g. keeping the code up to date, easier deployments
etc).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3772#comment:2>
