[GRASS-dev] [GRASS GIS] #3778: where field in wxgui layer manager d.vect display missing value on workspace import
trac at osgeo.org
Wed Mar 6 06:56:26 PST 2019
workspace import
Reporter: balagates | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: wxGUI | Version: svn-releasebranch76
Keywords: d.vect where | CPU: OSX/Intel
Platform: MacOSX |
In the WX d.vect Selection tab the "where" field is blank after importing
a GXW workspace file containing a "where" value (example workspace vector
parameters below). The preview of the d.vect command at the bottom of
the window is also missing the "where" parameter. The other parameters in
this workspace file (fill_color and icon) are displayed properly. The
strange thing is the Map Display is using the "where" value in the
workspace file even though it is not displayed in the WX d.vect
properties. If I manually type in the same "where" value the WX d.vect
works as expected. So this appears to be only a WX d.vect Selection
display problem after import from a GXW workspace file.
<layer type="vector" name="mrds_az at brett" checked="0"
opacity="1.000000">
<task name="d.vect">
<parameter name="map">
<value>mrds_az at brett</value>
</parameter>
<parameter name="where">
<value>COMMOD1='Gold'</value>
</parameter>
<parameter name="fill_color">
<value>orange</value>
</parameter>
<parameter name="icon">
<value>basic/box</value>
</parameter>
</task>
</layer>
I believe this worked fine in 7.4.1. I first noticed the problem in the
7.6.0 downloaded from the Grass site on my macOS 10.12.6.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3778>
