[GRASS-dev] [GRASS GIS] #3778: where field in wxgui layer manager d.vect display missing value on workspace import
trac at osgeo.org
Thu Mar 21 11:06:38 PDT 2019
workspace import
Reporter: balagates | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: wxGUI | Version: svn-releasebranch76
Resolution: | Keywords: d.vect where
CPU: OSX/Intel | Platform: MacOSX
Comment (by balagates):
I noticed in the layer manager when a line with a d.vect "where" parameter
is selected the status bar shows the d.vect command including the "where"
and other parameters. I also noticed that when you open a properties
dialog (CmdPanel) for that vector the d.vect command is also shown in the
dialog windows status bar but the "where" parameter has been removed.
Debugging I see the "where" parameter is in the get_cmd() thru the end of
GUI.ParseCommand() but it disappeared after the following code in
./gui_core/forms.py UpdateThread.run() is run.
pBind = self.task.get_param(uid, element='wxId',
raiseError=False)
if pBind:
pBind['value'] = ''
This may not be a bug by itself but seems related. What I cannot find is
a way for the "where" value imported by the Open Workspace to initialize
the dialog "where" value. The value I expect is destroyed in the above
code but maybe the initialization should happen elsewhere? As far as I
can tell this aspect of the code has not changed since 7.4 and I thought
this might have been working in 7.4 (not sure though). Other parameters
such as "icon" are not affected. There appears to be special handling for
SqlWhereSelect type parameters.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3778#comment:1>
