[GRASS-dev] Translations and command description/options
Panagiotis Mavrogiorgos
pmav99 at gmail.com
Wed Mar 6 11:20:11 PST 2019
hello everyone
After activating the french locale and running GRASS GIS with
LANG=fr_FR.UTF-8 LANGUAGE=fr_FR.UTF-8 LC_MESSAGES=fr_FR.UTF-8
> bin.x86_64-pc-linux-gnu/grass77
both the GUI and the TUI are translated. E.g.
__________ ___ __________ _______________
> / ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
> / / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
> / /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
> \____/_/ |_/_/ |_/____/____/ \____/___//____/
> Bienvenue dans le SIG GRASS 7.7.svn (exported)
> Page d'accueil du SIG GRASS : https://grass.osgeo.org
> Cette version fonctionne avec : Z Shell (/usr/bin/zsh)
> L'aide est disponible par la commande : g.manual -i
> Voir les termes de la licence avec : g.version -c
> Voir les termes de la licence avec : g.version -x
> Si requis, redémarrer l'interface graphique avec :g.gui wxpython
> Lors prĂȘt pour la fermeture entrer : exit
Nevertheless, the command descriptions and options are not. E.g.:
r3.cross.rast --help
> Creates cross section 2D raster map from 3D raster map based on 2D
> elevation map
> Usage:
> r3.cross.rast [-m] input=string elevation=string output=string
> [--overwrite] [--help] [--verbose] [--quiet] [--ui]
> Flags:
> -m Use 3D raster mask (if exists) with input map
> Parameters:
> input Input 3D raster map for cross section
> elevation 2D elevation map used to create the cross section map
> output Resulting cross section 2D raster map
The question is: Are command description supposed to be translated too or
not? I mean, is everything working as expected or is there something wrong
in my setup?
with kind regards,
Panos
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190306/2d24abcb/attachment.html>
