[GRASS-dev] [GRASS GIS] #3771: Run tests on Travis
trac at osgeo.org
Wed Mar 6 23:18:12 PST 2019
Reporter: pmav99 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Tests | Version: svn-trunk
Resolution: | Keywords:
CPU: Unspecified | Platform: Unspecified
Comment (by pmav99):
Running tests on CI doesn't really make sense if you have failing tests:
http://fatra.cnr.ncsu.edu/grassgistests/summary_report/nc/index.html
So the next step should be to make the tests pass.
- Ideally, the failing tests should be fixed.
- If that is not possible the tests should be marked as expected to fail.
- If that is not possible then I would suggest removing them for now +
opening an issue to re-add them when they are fixed (one issue per removed
test)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3771#comment:3>
