[GRASS-dev] [GRASS GIS] #3771: Run tests on Travis
GRASS GIS trac at osgeo.org
Wed Mar 6 23:59:59 PST 2019
  Reporter:  pmav99       |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:
 Component:  Tests        |    Version:  svn-trunk
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by sbl):
 Replying to [comment:3 pmav99]:
 > Running tests on CI doesn't really make sense if you have failing tests:
 http://fatra.cnr.ncsu.edu/grassgistests/summary_report/nc/index.html
 To my knowledge, most of the tests that are currently failing, started
 failing due to fundamental changes from the introduction of Python 3, e.g.
 everything related to bytes vs. strings...
 So we would have to sort out those from tests that are failing for other
 reasons...
 > So the next step would be to make the tests pass.
 In general +1, but again, lets try to distinguish Pythen 3 related test
 failure from all others...
 Currently, somehow, most failing tests tell us how far we are from Python
 3 (and 2) support...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3771#comment:4>
