[GRASS-dev] GRASS GIS + PROJ 6 + GDAL 2.5
Markus Metz
markus.metz.giswork at gmail.com
Tue Mar 12 13:11:14 PDT 2019
Dear Roger,
On Fri, Mar 8, 2019 at 10:49 AM Roger Bivand <Roger.Bivand at nhh.no> wrote:
> Since rgdal::make_EPSG() is facing the same problems of listing tabulated
> EPSG fields as g.proj -l, I was very happy to see Markus' code in
> g.proj/main.c mentioned in this thread, and have used this approach in
https://r-forge.r-project.org/scm/viewvc.php/pkg/src/proj_info6.cpp?view=markup&root=rgdal
> However, there are plenty of messages such as: "proj_as_proj_string:
> Unsupported conversion method: Lambert Conic Conformal (West
Orientated)". I
> haven't installed GRASS trunk with PROJ6, so I can't see whether g.proj -l
> also sees the same messages. If it does, maybe we could ask on the proj
list
> how they might be captured for summary reporting. I think they are coming
> from line 5758 in src/iso19111/coordinateoperation.cpp or maybe line 906
in
> same file. Maybe PROJ now has an error handler that
> Another question concerns the issue of whether one needs to free objects
> created, in particular proj_crs_info and pj. Not so important for g.proj,
> which exists when done, but important for rgdal whose functions don't
exit.
> Anyway, very helpful to see that Markus is looking at the same issues as
we
> are!
Regarding parsing the traditional PROJ init files, I looked at pj_init.c in
PROJ 5 and earlier and attempted to improve parsing those traditional init
files in GRASS trunk r74224. I guess that R as well as GRASS is trying to
support PROJ versions from 4(.8) onwards.
Regards,
Markus M
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190312/4d60632b/attachment-0001.html>
