[GRASS-dev] GSoC Proposal: Python package for topology tools
Luca Delucchi lucadeluge at gmail.com
Wed Mar 27 16:31:55 PDT 2019
On Tue, 26 Mar 2019 at 03:11, Facundo Ferrin <facundo.ferrin at gmail.com> wrote:
> Hi there!
Hi Facundo,
> My name is Facundo Ferrin. I am a nuclear engineer who is taking a master in Computer Vision in Barcelona, and finally I found my opportunity to contribute to OSGeo by applying two things that I really like: Python and Backend development . I do not know exactly what I should write in this first email, so I'll start by listing the projects I'm interested in.
> I'm working in a company that is developing a platform for precision agriculture called Auravant (https://www.auravant.com/). I work as a backend developer and data analyst and I use daily almost every tool that you post in the ideas: GeoServer, PostGIS, QGis. I'm also porting a tool for polygon simplification called topoJSON (https://github.com/fferrin/topojson).
> MY MAIN IDEA is to start porting GRASS tools into a python package that can be used in other projects (beyond the client to use by command line). I don't know if it's something you have in mind but for offline and automated analysis it would be very useful. I particularly had problems when I tried to simplify geometries since the geometry of polygons was not taken into account.
Your idea is not clear to me, there are already two Python library to
work with GRASS. you can find some ideas in the proposal page
https://trac.osgeo.org/grass/wiki/GSoC/2019 (for example
Neweasy-to-useCLIandAPIforGRASSGIS) and
https://trac.osgeo.org/grass/wiki/GSoC/2018 (Improve GRASS integration
in QGIS 3)
> Hope to hear from you soon!
ciao
Luca
www.lucadelu.org
