[GRASS-dev] [GRASS GIS] #3771: Run tests on Travis
GRASS GIS trac at osgeo.org
Sat Mar 30 19:05:21 PDT 2019
  Reporter:  pmav99       |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:
 Component:  Tests        |    Version:  svn-trunk
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by wenzeslaus):
 Replying to [comment:16 neteler]:
 > At time the "fatra" server no longer runs, it is frozen at date
 > 2019-03-26 03:01:54   74304   nc_spm_full_v2alpha     93%     98%
 > @vaclav: could you please check? thanks
 > http://fatra.cnr.ncsu.edu/grassgistests/summary_report/nc/index.html
 Seems like a minor issue so far. Tests should still run locally (if you
 try). I should know more tomorrow (debug message added).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3771#comment:20>
