[GRASS-dev] [GRASS GIS] #3771: Run tests on Travis
trac at osgeo.org
Sat Mar 30 19:14:57 PDT 2019
Reporter: pmav99 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Tests | Version: svn-trunk
Resolution: | Keywords:
CPU: Unspecified | Platform: Unspecified
Comment (by wenzeslaus):
Replying to [comment:6 sbl]:
> * **Crack down on the other 10%** of failing test (fix or deactivate
temporarily if necessary as you suggest)
You don't need 100% passing to run it on CI reasonably. That's the ideal
state, but we can start with setting a threshold to what you consider OK.
The idea is already there. Notice the colors of the percentages. What you
need to add is mechanism for the main script to fail and not fail with a
given success percentage value. This would catch serious problems, but
that will be still quite a progress. So far it was mostly me checking the
fatra server website and reporting it to mailing list (or, I think,
directly to the committer in one recent case).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3771#comment:21>
