[GRASS-dev] [GRASS GIS] #3832: Add environment variable to create all temp-files at a user-defined location (outside the mapsets)
GRASS GIS trac at osgeo.org
Thu May 2 06:20:52 PDT 2019
  Reporter:  sbl          |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  normal       |  Milestone:  7.8.0
 Component:  Default      |    Version:  svn-trunk
Resolution:               |   Keywords:  environment variables
       CPU:  Unspecified  |   Platform:  All
Comment (by neteler):
 As a workaround you could simply replace the location/mapset/.tmp/
 with a link to a directory on SSD.
 However, from the planning document:
 https://trac.osgeo.org/grass/wiki/Grass8Planning#Rasterlibrary
  * "implement GRASS_RASTER_TMPDIR_MAPSET like it exists for vector data
 (GRASS_VECTOR_TMPDIR_MAPSET), i.e. change all .tmp/ to variable in source
 code in init/grass.py, gis/open.c, gis/file_name.c, raster library"
 Maybe to be worked out in more detail but for sure very important (we
 frequently face the same issue).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3832#comment:1>
