[GRASS-dev] [GRASS GIS] #3832: Add environment variable to create all temp-files at a user-defined location (outside the mapsets)
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Sat May 4 12:13:21 PDT 2019
Hi Markus,
And thanks for the info/feedback.
Although the redirection of the .tmp directory (in future through an environment variable hopefully) already helps quite a bit and is a rather simple remedy (from the user perspective), intermediate maps can still cause similar issues.
Inspired by g.cloud, I tend to setup a local GRASS DB on SSD, where I link / copy mapsets from network storage as needed for the process. That way, (script based) processing does not affect snapshot backup at all. So, my follow up question is if a Python function to create a local grass DB from a central GRASS DB on network storage might be useful.
I am thinking along the following lines:
def setup_local_db(local_db_path, network_db_path, link_locations_mapsets, copy_locations_mapsets):
"""creates a local GRASS DB by linking or copying a user defined list of mapsets from a GRASS DB on network storage
:param local_db_path: path where the local GRASS DB should be created
:type local_db_path: str
:param network_db_path: path to the GRASS DB on network storage from which mapsest should be linked / copied
:type network_db_path: str
:param link_locations_mapsets: tuple with combinations of (location, mapset) to be linked to local GRASS DB
:type link_locations_mapsets: tuple
:param copy_locations_mapsets: tuple with combinations of (location, mapset) to be copied to local GRASS DB
:type copy_locations_mapsets: tuple
Would that be suitable for the GRASS code base? Such a function seems little helpful to run from within an existing GRASS session, so an addon does not seem to make very much sense either, right? Maybe if Panos work on making grass modules importable without existing session is successful, one could setup local db and then start a session. But maybe this would be more suitable for grass-session?
Any comments recommendations, suggestions are most welcome...
Cheers,
Stefan
-----Original Message-----
Sent: torsdag 2. mai 2019 15:21
Cc: grass-dev at lists.osgeo.org
Subject: Re: [GRASS GIS] #3832: Add environment variable to create all temp-files at a user-defined location (outside the mapsets)
Reporter: sbl | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.8.0
Component: Default | Version: svn-trunk
Resolution: | Keywords: environment variables
CPU: Unspecified | Platform: All
Comment (by neteler):
As a workaround you could simply replace the location/mapset/.tmp/ with a link to a directory on SSD.
However, from the planning document:
https://trac.osgeo.org/grass/wiki/Grass8Planning#Rasterlibrary
* "implement GRASS_RASTER_TMPDIR_MAPSET like it exists for vector data (GRASS_VECTOR_TMPDIR_MAPSET), i.e. change all .tmp/ to variable in source code in init/grass.py, gis/open.c, gis/file_name.c, raster library"
Maybe to be worked out in more detail but for sure very important (we frequently face the same issue).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3832#comment:1>
