[GRASS-dev] Which is the correct WIND convention for creating a new mapset?
Markus Metz
markus.metz.giswork at gmail.com
Tue May 7 13:03:42 PDT 2019
On Tue, May 7, 2019 at 10:20 AM Panagiotis Mavrogiorgos <pmav99 at gmail.com>
wrote:
> On Mon, May 6, 2019 at 9:38 PM Markus Metz <markus.metz.giswork at gmail.com>
wrote:
>> On Mon, May 6, 2019 at 6:21 PM Panagiotis Mavrogiorgos <pmav99 at gmail.com>
wrote:
>> > Hello all,
>> > I am a bit confused WRT what the expected WIND should be when you
create a new mapset.
>> > Is there an established convention?
>> IMHO, new mapsets should use DEFAULT_WIND from PERMANENT.
> Thank you Markus, that's what I expected, too.
>> But the current region of a new mapset is often adjusted, therefore it
does not really matter if DEFAULT_WIND or WIND is used.
> I don't disagree, but still, I don't see what's the benefit of not using
the same convention everywhere. Furthermore, I truly don't understand why 4
different implementations are needed.
True, g.mapset -c should be used whenever possible. I adjusted the wxGUI
startup wizard and the tests in trunk r74472,3 (the tests should use
g.mapset -c, not yet implemented)
Markus M
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190507/88f76a28/attachment.html>
