[GRASS-dev] Which is the correct WIND convention for creating a new mapset?
Markus Metz
markus.metz.giswork at gmail.com
Wed May 8 12:54:40 PDT 2019
On Wed, May 8, 2019 at 10:22 AM Panagiotis Mavrogiorgos <pmav99 at gmail.com>
wrote:
> On Tue, May 7, 2019 at 11:03 PM Markus Metz <markus.metz.giswork at gmail.com>
wrote:
>> On Tue, May 7, 2019 at 10:20 AM Panagiotis Mavrogiorgos <pmav99 at gmail.com>
wrote:
>> > On Mon, May 6, 2019 at 9:38 PM Markus Metz <
markus.metz.giswork at gmail.com> wrote:
>> >> On Mon, May 6, 2019 at 6:21 PM Panagiotis Mavrogiorgos <
pmav99 at gmail.com> wrote:
>> >> > Hello all,
>> >> > I am a bit confused WRT what the expected WIND should be when you
create a new mapset.
>> >> > Is there an established convention?
>> >> IMHO, new mapsets should use DEFAULT_WIND from PERMANENT.
>> > Thank you Markus, that's what I expected, too.
>> >> But the current region of a new mapset is often adjusted, therefore
it does not really matter if DEFAULT_WIND or WIND is used.
>> > I don't disagree, but still, I don't see what's the benefit of not
using the same convention everywhere. Furthermore, I truly don't understand
why 4 different implementations are needed.
>> True, g.mapset -c should be used whenever possible.
> I would argue that it is G_make_mapset() that should be used whenever
possible :)
> (which of course, is being used by g.mapset -c, too)
It depends. g.mapset changes the current mapset (and location and
database). It might also create a new mapset in an existing location, but
it always switches. If that switch is not desired, GISRC must be adjusted
to the original GRASS session. G_make_mapset() is a C function and should
be used by C modules. Of course you could use it with pygrass, but pygrass
initializes the GRASS C libraries, and you need to take care that
initializations are properly updated when changing mapsets (and locations).
Creating a new mapset in an existing location is not difficult: create the
folder and copy DEFAULT_WIND from PERMANENT to WIND in the new mapset.
Maybe create a new function create_mapset() in lib/python/script/utils.py?
>>> I adjusted the wxGUI startup wizard and the tests in trunk r74472,3
(the tests should use g.mapset -c, not yet implemented)
> I think that in the nc_spm_full_v2alpha dataset WIND and DEFAULT_WIND
differ, so 74473 might break any tests that don't explicitly set the region
themselves (which of course they should). We will see.
IMHO, tests need to set the region themselves, just as users. The current
region is such a fundamental concept of GRASS (raster processing) that I
regard it as a mistake if the current region is not explicitly set to
actual demands.
Markus M
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190508/33afc030/attachment.html>
