[GRASS-dev] [GRASS GIS] #3843: cartographic composer only previews and outputs in profile aspect (no landscape)
trac at osgeo.org
Fri May 10 05:46:14 PDT 2019
landscape)
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.6.2
Component: wxGUI | Version: svn-releasebranch76
Resolution: | Keywords: cartographic composer, aspect mode
CPU: Unspecified | Platform: MacOSX
Changes (by veroandreo):
* milestone: => 7.6.2
Comment:
I can confirm this. Tested here with 76 relbranch and trunk r74471 in a
Fedora box. If I set the page to landscape, both the preview and output
pdf file are not landscape. Moreover the pdf must be rotated 90 degrees to
get a landscape map.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3843#comment:1>
