[GRASS-dev] [gdal-dev] GDAL 3.0.0 is released
Stefan Blumentrath Stefan.Blumentrath at nina.no
Fri May 10 12:53:52 PDT 2019
FYI. Maybe of interest...
________________________________________
Fra: gdal-dev <gdal-dev-bounces at lists.osgeo.org> på vegne av Even Rouault <even.rouault at spatialys.com>
Sendt: torsdag 9. mai 2019 12.54
Til: gdal-dev at lists.osgeo.org; gdal-announce at lists.osgeo.org; news_item at osgeo.org
Emne: [gdal-dev] GDAL 3.0.0 is released
On behalf of the GDAL/OGR development team and community, I am pleased to
announce the release of GDAL/OGR 3.0.0.  GDAL/OGR is a C++ geospatial
data access library for raster and vector file formats, databases and
web services.  It includes bindings for several languages, and a variety
of command line tools.
   http://www.gdal.org/
The 3.0.0 release is a new feature release with the following highlights:
 * Implement RFC 73: Integration of PROJ6 for WKT2, late binding capabilities,
time-support and unified CRS database.
    ==> PROJ >= 6 is now a build requirement
    https://trac.osgeo.org/gdal/wiki/rfc73_proj6_wkt2_srsbarn
 * New GDAL drivers:
  - DAAS: read driver for Airbus DS Intelligence Data As A Service
  - TileDB: read/write driver for https://www.tiledb.io (#1402)
 * New OGR drivers:
  - MongoDBv3: read/write driver using libmongocxx v3.4.0 client (for MongoDB
>= 4.0)
 * Improved drivers:
   - FITS: read/write support for scale, offset and CRS
   - netCDF: read support for groups
   - PDF: add a COMPOSITION_FILE creation option to generate a complex
document
   - PDS4: subdataset creation support, read/write table/vector support
 * Support for minimal builds on Unix (#1250)
 * Add a docker/ directory with Dockerfile for different configurations
 * Continued code linting
More complete information on the new features and fixes in the 3.0.0
release can be found at:
  http://trac.osgeo.org/gdal/wiki/Release/3.0.0-News
The release can be downloaded from:
  * http://download.osgeo.org/gdal/3.0.0/gdal300.zip - source as a zip
  * http://download.osgeo.org/gdal/3.0.0/gdal-3.0.0.tar.gz - source as .tar.gz
  * http://download.osgeo.org/gdal/3.0.0/gdal-3.0.0.tar.xz - source as .tar.xz
  * http://download.osgeo.org/gdal/3.0.0/gdal-grass-3.0.0.tar.gz - GDAL-GRASS
plugin
  * http://download.osgeo.org/gdal/3.0.0/gdalautotest-3.0.0.tar.gz - test
suite
  * http://download.osgeo.org/gdal/3.0.0/gdal300doc.zip - documentation /
website
The migration guide can be found at  :
      https://github.com/OSGeo/gdal/blob/release/3.0/gdal/MIGRATION_GUIDE.TXT
Best regards,
Even
http://www.spatialys.com
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190510/2c8fd8cc/attachment.html>
