[GRASS-dev] [EXTERNAL] Re: [gdal-dev] GDAL 3.0.0 is released
Newcomb, Doug
doug_newcomb at fws.gov
Mon May 13 04:41:45 PDT 2019
Gdal 3.0, Proj 6, Python 3 only. Would this be sufficient change for an
8.0 release?
Doug
On Fri, May 10, 2019 at 3:55 PM Stefan Blumentrath <
Stefan.Blumentrath at nina.no> wrote:
> FYI. Maybe of interest...
> ________________________________________
> Fra: gdal-dev <gdal-dev-bounces at lists.osgeo.org> på vegne av Even Rouault
> <even.rouault at spatialys.com>
> Sendt: torsdag 9. mai 2019 12.54
> Til: gdal-dev at lists.osgeo.org; gdal-announce at lists.osgeo.org;
> news_item at osgeo.org
> Emne: [gdal-dev] GDAL 3.0.0 is released
> Hi,
> On behalf of the GDAL/OGR development team and community, I am pleased to
> announce the release of GDAL/OGR 3.0.0. GDAL/OGR is a C++ geospatial
> data access library for raster and vector file formats, databases and
> web services. It includes bindings for several languages, and a variety
> of command line tools.
> http://www.gdal.org/
> The 3.0.0 release is a new feature release with the following highlights:
> * Implement RFC 73: Integration of PROJ6 for WKT2, late binding
> capabilities,
> time-support and unified CRS database.
> ==> PROJ >= 6 is now a build requirement
> https://trac.osgeo.org/gdal/wiki/rfc73_proj6_wkt2_srsbarn
> * New GDAL drivers:
> - DAAS: read driver for Airbus DS Intelligence Data As A Service
> - TileDB: read/write driver for https://www.tiledb.io (#1402)
> * New OGR drivers:
> - MongoDBv3: read/write driver using libmongocxx v3.4.0 client (for
> MongoDB
> >= 4.0)
> * Improved drivers:
> - FITS: read/write support for scale, offset and CRS
> - netCDF: read support for groups
> - PDF: add a COMPOSITION_FILE creation option to generate a complex
> document
> - PDS4: subdataset creation support, read/write table/vector support
> * Support for minimal builds on Unix (#1250)
> * Add a docker/ directory with Dockerfile for different configurations
> * Continued code linting
> More complete information on the new features and fixes in the 3.0.0
> release can be found at:
> http://trac.osgeo.org/gdal/wiki/Release/3.0.0-News
> The release can be downloaded from:
> * http://download.osgeo.org/gdal/3.0.0/gdal300.zip - source as a zip
> * http://download.osgeo.org/gdal/3.0.0/gdal-3.0.0.tar.gz - source as
> .tar.gz
> * http://download.osgeo.org/gdal/3.0.0/gdal-3.0.0.tar.xz - source as
> .tar.xz
> * http://download.osgeo.org/gdal/3.0.0/gdal-grass-3.0.0.tar.gz -
> GDAL-GRASS
> plugin
> * http://download.osgeo.org/gdal/3.0.0/gdalautotest-3.0.0.tar.gz - test
> suite
> * http://download.osgeo.org/gdal/3.0.0/gdal300doc.zip - documentation /
> website
> The migration guide can be found at :
> https://github.com/OSGeo/gdal/blob/release/3.0/gdal/MIGRATION_GUIDE.TXT
> Best regards,
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Doug Newcomb - Cartographer
USFWS
551F Pylon Dr
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb at fws.gov
*NOTE: This email correspondence and any attachments to and from this
sender is subject to the Freedom of Information Act (FOIA) and may be
disclosed to third parties.*
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190513/59778d48/attachment-0001.html>
