[GRASS-dev] git: how to avoid bogus merge commits
    Panagiotis Mavrogiorgos
    pmav99 at gmail.com
    Thu May 23 03:11:40 PDT 2019
st 22. 5. 2019 v 21:44 odesÃlatel Even Rouault
> <even.rouault at spatialys.com <https://lists.osgeo.org/mailman/listinfo/grass-dev>> napsal:
> >* git fetch origin  (assuming 'origin' point to OSGeo/grass)
> *>* git rebase origin/master
> or possibly
> git pull --rebase
git pull --rebase can be indeed used to the same effect. You can even add
[pull]
    rebase = true
to your .gitconfig.
Nevertheless, IMHV it is still a better idea to use a personal fork + Pull
Requests instead of the main repo. With this workflow, even if you do
something messy you can always sort it out without adding noise to history
I have updated the section
> Keep your local source code up to date
> https://trac.osgeo.org/grass/wiki/HowToGit#Keepyourlocalsourcecodeuptodate
The stash step was wrong. I fixed it. In order to reapply the stash you
need:
    git stash apply && git stash pop
This way the stash is being popped if and only if it has been applied
cleanly. If there are conflicts you can reset the repo without losing your
stash (which you might want to apply to a different branch etc).
P.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190523/f59bc92f/attachment.html>
