[GRASS-dev] grass-addons on github
Martin Landa landa.martin at gmail.com
Fri May 24 04:39:18 PDT 2019
pá 24. 5. 2019 v 9:54 odesílatel Martin Landa <landa.martin at gmail.com> napsal:
> in my opinion requesting PRs for `grass-addons` is maybe overkill. It
> must be somehow discussed anyway. If we suggest direct commits it's
> important to avoid not needed 'merge from master' commits [1]. The
> workflow must be clear (rebase always) to avoid such situations. It
> was not defined yet. Even suggested workflow related to the main
> repository is not clearly defined [2]. This must be improved in a near
> future.
draft added [1]. Ma
[1] https://trac.osgeo.org/grass/wiki/HowToGit#Workflowforgrass-addonsrepository
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
