[GRASS-dev] Setting up the Github backport application
Even Rouault
even.rouault at spatialys.com
Sun May 26 08:24:06 PDT 2019
On dimanche 26 mai 2019 16:31:04 CEST Markus Neteler wrote:
> Hi,
> we activated the backport bot also for GRASS GIS in the Gihub OSGeo
> organization.
> As far as I understood from Even's email
> https://lists.osgeo.org/pipermail/gdal-dev/2019-March/049928.html
> the system is fairly straight forward (activate bot, define a new
> "backport <branch>" label, set it to a PR).
> So I tested it with a trivial README.md change but it didn't
> cherry-pick but tried to backport the entire master to release_branch
> differences!
Where did you try ? I can't see any "backport XXXX" label in
https://github.com/OSGeo/grass/labels nor a pull request with the label.
Even
http://www.spatialys.com
