[GRASS-dev] (no subject)
Paulo van Breugel
p.vanbreugel at gmail.com
Mon May 27 02:38:58 PDT 2019
Hi Maris
Thanks, your suggestion made me realize that I did not recompiled the
gdal-grass plugin (which was still pointing to a grass 7.5 version).
Great, all working again.
Cheers,
Paulo
On 5/27/19 11:33 AM, Maris Nartiss wrote:
> Hello,
> usually it indicates on some remnants of previous version lying around
> somewhere. Check out also for all extensions or your own custom
> modules as they need to be rebuilt too.
> Māris.
> piektd., 2019. g. 24. maijs, plkst. 18:18 — lietotājs Paulo van
> Breugel (<p.vanbreugel at gmail.com>) rakstīja:
>> Hi devs
>> I just did a completely fresh install of grass 7.6.2. The whole compilation is completed without issues. But when starting grass up, I am getting the following message.
>> GRASS 7.6.2svn (nc_spm_08_grass7):~ > ERROR 1: libgrass_raster.7.5.svn.so: cannot open shared object file: No such file or directory
>> I started completely anew, removed everything before compiling (as far as I know), including the .grass7 folder, so I wonder what else I could have done wrong? Any idea how I can find out where the problem lies?
>> Cheers,
>> Paulo
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
