[GRASS-dev] Forestfrag WARNING: ZSTD compression error -14: Unsupported frame parameter
Paulo van Breugel
p.vanbreugel at gmail.com
Mon May 27 12:25:22 PDT 2019
Hi Václav / devs
I am running r.forestfrag in Windows 10, grass 7.6.2 Computation with a
moving window size of 21 (but at another computer same happens at size
9) gives met the following error:
C:\Users\brp\AppData\Roaming\GRASS7\addons/scripts/r.forestfrag.py
input=groenreclass at landschap output=AAtest7 size=21
Step 1: Computing Pf values...
Step 2: Computing Pff values...
ERROR: Error uncompressing raster data for row 328 of
<tmpA04_398bad3c_32a8_4220_8566_374c8c9f16a8>
WARNING: No data base element files found
File
"C:\Users\brp\AppData\Roaming\GRASS7\addons/scripts/r.forestfrag.py",
line 420, in <module> sys.exit(main(*gs.parser()))
File
line 290, in main ipl=ipl, tmpl4=expr1, tmpl5=expr2, pff=pff)
File
"C:\OSGEO4~1\apps\grass\grass76\etc\python\grass\script\raster.py", line
111, in mapcalc " with expression: %s") % e)
File
"C:\OSGEO4~1\apps\grass\grass76\etc\python\grass\script\core.py", line
667, in fatal error(msg)
File
651, in error message(msg, flag='e')
File
584, in message run_command("g.message", flags=flag, message=msg,
errors='ignore')
File
415, in run_command ps = start_command(*args, **kwargs)
File
382, in start_command
return Popen(args, **popts)
File
76, in __init__ subprocess.Popen.__init__(self, args, **kwargs)
File "C:\OSGEO4~1\apps\Python27\lib\subprocess.py", line 390, in
__init__ errread, errwrite)
File "C:\OSGEO4~1\apps\Python27\lib\subprocess.py", line 640, in
_execute_child startupinfo)
WindowsError: [Error 206] De bestandsnaam of -extensie is te lang
Any idea what may be the problem here?
Greetings,
Paulo
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190527/86197908/attachment.html>
