[GRASS-dev] How to commit changes in git to a release_branch?
Panagiotis Mavrogiorgos pmav99 at gmail.com
Tue May 28 01:14:45 PDT 2019
hello Markus
In git, a "remote" is a different repository that you share common history
with. It usually exists on a different server, but it can also live on your
filesystem.
In your case you pushed the commit to your origin which is
"grass-p3/master". You can check that by cd-ing into "grass-p3/master" and
running "git log releasebranch_7_4". You should see the commit there. So if
you want to push that to the main repo, you can do it either from
"grass-p3/master" or you can add the main repo as a remote to
"grass-p2/releasebranch_7_4"
all the best,
P.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190528/618229ef/attachment.html>
