[GRASS-dev] [GRASS GIS] #3930: reprojection error in r.proj / GRASS 7.8.1 -- N-S-coordinates interchanged with W-E
GRASS GIS trac at osgeo.org
Sat Nov 2 08:45:45 PDT 2019
with W-E
  Reporter:  guilo               |      Owner:  grass-dev@…
      Type:  defect              |     Status:  new
  Priority:  normal              |  Milestone:
 Component:  Projections/Datums  |    Version:  git-releasebranch78
Resolution:                      |   Keywords:
       CPU:  x86-64              |   Platform:  Linux
Comment (by mmetz):
 Replying to [ticket:3930 guilo]:
 > = Description =
 > There is observed a serious error in map reprojection, using r.proj,
 resulting in an interchange of N-S-coordinates with those of East-West.
 > The error occurs in GRASS version 7.8 (proj4 version 6.2, gdal version
 2.42), in the reprojection with r.proj, from a newly created source map
 projection, to an existent target map projection. Repeating the same
 procedure, but using a formerly created source map projection (same
 projection, but prior to GRASS 7.6), the maps are reprojected in a correct
 way.
 You must have used GRASS 7.8.0, not GRASS 7.8.1
 This can only happen in GRASS 7.8.0 and has already been fixed in GRASS
 7.8.1, soon to be released.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3930#comment:1>
