[GRASS-dev] PROJ6 support in GRASS
Martin Landa landa.martin at gmail.com
Thu Nov 7 12:39:32 PST 2019
Hi Markus,
čt 7. 11. 2019 v 19:50 odesílatel Markus Metz
<markus.metz.giswork at gmail.com> napsal:
> yes, EPSG:3857 is causing trouble. This is the WGS 84 / Pseudo-Mercator projection on a sphere with radius 6378137 that needs special treatment which no longer works with GRASS + PROJ 6 + GDAL 3.
I will try to reword my question. Are you aware of any related
blockers which should avoid us packaging upcoming GRASS 7.8.1 with
GDAL3/Proj6? Thanks for clarification! Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
