[GRASS-dev] PROJ6 support in GRASS
Markus Metz markus.metz.giswork at gmail.com
Thu Nov 7 23:22:30 PST 2019
On Thu, Nov 7, 2019 at 9:39 PM Martin Landa <landa.martin at gmail.com> wrote:
> Hi Markus,
> čt 7. 11. 2019 v 19:50 odesílatel Markus Metz
> <markus.metz.giswork at gmail.com> napsal:
> > yes, EPSG:3857 is causing trouble. This is the WGS 84 / Pseudo-Mercator
projection on a sphere with radius 6378137 that needs special treatment
which no longer works with GRASS + PROJ 6 + GDAL 3.
> I will try to reword my question. Are you aware of any related
> blockers which should avoid us packaging upcoming GRASS 7.8.1 with
> GDAL3/Proj6? Thanks for clarification! Martin
No, that's the only bug I found so far.
Markus M
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20191108/dcf77eeb/attachment.html>
