[GRASS-dev] compila grass on fedora31: configure: error: *** Unable to locate GDAL library.
Pietro
peter.zamb at gmail.com
Mon Nov 11 04:13:24 PST 2019
Dear devs,
I have an issue when* I* try to configure ad compile grass.
At the moment I'm on Fedora 31. So I installed the default gdal (2.3.2)
with:
`sudo dnf install gdal gdal-devel gdal-libs`
I executed locally gdalinfo on a tif and it provide the information of the
raster and then I checked the installation paths with:
$ /usr/bin/gdal-config --version
2.3.2
$ /usr/bin/gdal-config --libs
-L/usr/lib64 -lgdal
$ /usr/bin/gdal-config --cflags
-I/usr/include/gdal
$ /usr/bin/gdal-config --datadir
/usr/share/gdal
So it seems to work, then my configure command is:
$ CFLAGS="-g -O1 -Wall -Wextra -Wundef -Wfloat-equal -Wpointer-arith
-Wcast-align -Wstrict-prototypes -Wstrict-overflow=5 -Wwrite-strings
-Wshadow -Werror-implicit-function-declaration -Waggregate-return
-Wcast-qual -Wswitch-default -Wswitch-enum -Wconversion -Wunreachable-code
-Winit-self -Wuninitialized -fno-common -fexceptions -fstack-protector
-fmudflap -m64 -mtune=native" \
CXXFLAGS="-g -O1 -Wall" \
./configure \
--prefix=$HOME/.local \
--with-zstd \
--with-blas --with-blas-includes=/usr/include/atlas-x86_64-base/ \
--with-lapack --with-lapack-includes=/usr/include/atlas-x86_64-base/ \
--with-cxx \
--with-cairo \
--with-freetype \
--with-geos \
--with-gdal-includes=/usr/include/gdal \
--with-gdal-libs=/usr/lib64 \
--with-gdal-share=/usr/share/gdal \
--with-nls \
--with-netcdf \
--with-odbc \
--with-openmp \
--with-postgres \
--with-python=/usr/bin/python3-config \
--with-readline \
--with-proj \
--with-pthread \
--with-sqlite \
--with-wxwidgets=/usr/bin/wx-config
But I get the following error:
checking host system type... x86_64-pc-linux-gnu
checking for gcc... gcc
checking whether to use GDAL... yes
checking for gdal-config... /usr/bin/gdal-config
Do you understand why I still receive this error even if I specify all the
paths of the gdal iclude/libs/share directories?
Any ideas on how to solve/fix this issue?
Thank you for your support.
Pietro
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20191111/3fa717ab/attachment.html>
